Baby octopus
Hi,
I need help in setting if simplest of the network
I have many systems which are connected to 10/100/1000 Dlink switch. This is a Dlink 1016D switch. So there is no internet in this network. Now I want to connect it to the internet. What is the way to do this?
1. I know I can connect a router to one port of this switch and the router is connected to the WAN. This will work but I'm worried if all the traffic between the systems will route through this router??
2. If the answer to the above question is YES, will it happen if only if DHCP server on the router is enabled?
3. How will I efficiently set this network? Will getting a switch with an inbuilt router help?
~BO
~BO
