need help in finding a motherboard with pci 3.0 slot
mrxplek
im buying a gtx670 graphics card.i had decided to buy asrock z77 pro4 but it is currently out of stock.i need help finding a motherboard with pci 3.0. my budget for the motherboard is 5k-10k.my processor is i5 2500k.
ShintaiDK
20,378
You need an Ivy Bridge CPU to get PCIe 3.0. But the difference between PCIe 2.0 and 3.0 for you is 0-1%.
Lone Fox
21
The ASRock pro3 is essential the same (correct me if I'm wrong) and a little bit less. Doesn't have optical output.
Are you located in America?
mrxplek
so the performance of my graphics card will not be affected if i buy a motherboard with pci 2.0 slot?
.no i'm from india
ShintaiDK
20,378
.no i'm from india
The x16 is handled by the CPU. And your CPU is PCIe 2.0. So nomatter what motherboard you buy it will be 2.0.
And no, performance wise there is no difference for single graphic card setups.
TemjinGold
3,050
65
You need to be running like two 680s/two 7970s for PCI-E to have a difference and even then it's like a 3-5% difference.
