- Jul 3, 2005
- 2
- 0
- 0
On arriving home in the evening the other day I found my computer was continuously beeping (loudly) and the power LED on the front panel and the keyboard LEDs were continuously flashing. I have since tried a few trouble-shooting steps, but I have not been able to boot the machine. The only thing that happens when I power it up is the continuous flashing of power LED and keyboard LEDs. I am sure I had turned the computer off before I left home on the said day. I know there were thunderstorms and lightning in the area that day. From my trouble-shooting I realized that the TV tuner (specifically the WinTV PVR USB2) connected to the machine through USB now does not function - tried it on other machine(s) to make that conclusion. And I am guessing therefore that the root cause of the problem is that I had the radio (FM) areial/antenna connected to the WinTV. The lightning seems to have therefore affected the computer through the WinTV device which is connected to the computer using USB.
I am wondering if the above mentioned symptoms surely indicate that the computer is fried. Or are there any specific things I can try out to figure it out. Also, is it safe to salvage any components from this machine and try using them in another machine? I have quite a few upgrades performed on this machine since I bought it couple of years back.
Thanks in advance.
Thanks in advance.
