Need Help In Choosing The Right Power Supply and Number of Fans For My Rigged AMD System (PLEASE HELP)
imported_Deep
4
Need help in finding out right power supply for my comp. and also the recommended number of Fans. Here are the specs of my Computer.
Alright here is what i got:
1. CPU: AMD Athlon 64 3000+
2. Motherboard: MSI K8N Neo Platinum (nForce3 250Gb)
3. Computer Case: Antec SLK2650-BQE Mid Tower
4. Storage: Seagate Barracuda 200GB 7200RPM Plus (8MB cache) ATA
5. Memory: 2 X 512MB OCZ PC3200 EL Dual Channel Platinum
6. Optical Storage#1: Lite-On 52x32x52x16 Combo CD-RW/DVD-ROM drive
7. Optical Storage#2: NuTech DDW-082 8X DVD+/-RW
8. Video: 128MB ATI Radeon 9800 Pro, DVI, TV-out
The Case comes with the following:
1 350 Watt SmartPower ATX12V PSU
Cooling Capacity:
-1 120mm Rear Fan Specs: -RPM: 1200 -CFM: 38.94 -dB(A): 25
-1 80mm front (Not Included)
-Chassis Air Guide (standard) with optional 80mm fan (Not Included)
The Case has only room for three fans, should I replace the power supply and the 120mm rear fan and what kind of power supply or 80mm fans should i get?
So Yeah, Please help me out.:confused:
Tab
12,145
Just leave it, it should work fine....if the temps get hot get a 80mm for the front. I'd reconsider your graphics card.
