Originally posted by: solofly
Your link takes me to MS.com.
Originally posted by: Keeir
The Sony has the X-Brite Coating which will make the monitor look great without alot of tinkering... as long as you have low/indirect lighting sources. The glare at my local best buy on those screens has always turned me off.
The Dell has significantly more screen resolution and significantly better ergonomics as well as USB hub pass through.
Given that you have Sli GTX, I can't see a reason not to go Dell (or that Gateway 21" widescreen monitor at Best Buy)
Agreed 100%. You have the video cards to drive the 1680x1050 resolution (and then some), why not put them to use? Plus the Dell is usually cheaper than that monitor anyway...
(Although I agree that the new Gateway 21" widescreen may be worth taking a look at, as it apparently has support for several things the Dell doesn't - like HDCP, Component IIRC, and supposedly has a better scaler..)
Edit: I've also had the 2005FPW myself, for about 10 months now, and I've been extremely happy with it.
How is the quality of the games that you play? They look sharp or they have that dull LCD look?
