- Jan 6, 2001
- 53
- 0
- 0
I installed an AT power supply in my mother in laws computer because the fan went bad on her old one. Well now the thing wont post? If I pull the one side of the main connector with the blue and yellow wires off the Motherboard it will post but cant find the floppy or keyboard.
I figured I had a bad power supply so I put the old one back in and now its doing the same thing? This makes no sense to me anyone have any ideas?
There is a red and black small wire that might be the culprit? It comes off the power supply and I assume this was for the led mhz display on the front of the case as without it plugged in this doesnt light up however i didnt see where this wire came off of when i originally pulled the powersupply out.
Also there is an orange black and white small wire that is labled turbo sw which wasnt plugged in but im pretty sure this one was never plugged in as it was bundled up in a rubberband.
Please offer any suggestions as I really need to get her computer back up and running!
Thanks
Thanks
