- May 6, 2011
- 8,172
- 137
- 106
These parts are from a 2002 Silverado 1500 V6 2wd with a 8 ft bed.
This should be the end of the driveshaft. And the broken piece attached to it is the front u-joint.
Here is a closer look at the damage:
And I think this is a slip yoke, also damaged:
I guess my main question is, is the slip yoke itself damaged and in need of replaceemnt, or can I just replace those small circular parts that go inside it? Oh, and what are those two small parts that go inside the slip yoke? Do they come with a slip yoke when you order the part? Worst case, will I need anything more than a slip yoke and a u joint? The driveshaft fell off while the vehicle was parked so it shouldnt be damaged.
