photochop an arrow pointing at the source of the leak
I think you are pointing at the bolt-on section between the exhaust manifold and your pipe prior to the catalytic converter?
If you look closely you can see the belt in the rubber hose at the end of it, exhaust does not route through rubber hose 😉
lol, thx for the clearup 🙂
The engine bay in this car makes mine look like a model T
