- Apr 29, 2005
- 5,649
- 0
- 0
I was watching TV this weekend and some new home builder show was on. They were showing some of the upgrades that they put into their homes and they showed something that I didn't have time to look up then and I am unable to properly use the google to find today.
The item they showed basically looked like a main panel but for water. If memory serves me correctly, it was after the hot water heater and each water using device in the house had it's own dedicated in/out lines so that hot water didn't have to travel through all lines to get to the requesting unit. You also have the capability to turn off water for each device at this panel like you would a particular room via a circuit breaker box.
