Hi can someone tell me how I can transfer my mp3 files from my old win xp pc to a new win 8 pc . thx. both of my pcs are connected to the internet now
so i guest you have a router.make a sharing folder put all mp3 in.then go grab them from the folder
Not to be paranoid, but I wanna know who is in charge of encryption in these clouds? Including Apple's.
I recently got an offer form my provider, RCN for $5 a month for unlimited data cloud storage. I pasted about this here, and my little paranoia was kinda confirmed; so I stick to my internal backup strategy.
I would, personally still choose burn folder to DVD, will take no time, you don't have to sit around while it's burning, and you could use a DVD-RW! As the crow flys.
But, after learning yr options, you should obviously choose what is right for you.
My music is the ONLY thing I'll put on the cloud - nothing else. Even then, I have a slow upload, so it took me a few days to get it all there. The free Google Play account also gives me the added benefit of upgrading most of my songs to a higher bitrate as long as I access them online, with the ability to re-download them (at the original bitrates) if I have a hardware failure (essentially a 3rd backup supplementing my onsite backup, but I spent a lot of time and money on my collection so having another option is worth it).
If you are using cloud storage for anything else, though, you might be better off encrypting the files yourself before uploading them.
You can use Dropbox and drop the files in there by folder and pull them out on the other computer.
Im gonna buy a flash drive. I found this one
Corsair Flash Voyager GS USB 3.0 128GB Read 275MB/S Write 160MB/S USB Flash Drive
Is this backwards compatible with usb 2.0?
