Need help hooking up USBs
zamacman1
69
I have tried this once before and did not get it right. I have asus p4p800 not sure what kinda case. I have two usb wires coming from the front With four different wires to pug in
1 ground
1 vcc
1 -d
1 +d
My motherboard has a row of 5 on top and 4 below how does this plug in?
Bootprint
9,847
From the manual, +5 volts pin is towards the back side of the board.
Back of motherboard (towards pci slots)
.USB +5 [ ] USB+5
USB P5- [ ] USB P5-
USB P5+[ ] USB P5+
......GND [ ] GND
............. [ ] OC# (Do not connect OC# to GND)
zamacman1
69
.USB +5 [ ] USB+5
USB P5- [ ] USB P5-
USB P5+[ ] USB P5+
......GND [ ] GND
So does it plug in on top row in this order??
+d
-d
vcc
ground?
zamacman1
69
If I have this hooked up wrong will it burn up what ever I have pluged into it? I turned it on and did not see any smoke
thraxes
1,974
.USB +5 [ ] USB+5
USB P5- [ ] USB P5-
USB P5+[ ] USB P5+
......GND [ ] GND
+d
-d
vcc
ground?
Errr isn't that supposed to be:
vcc
d-
d+
GND
