Need help hooking up Logitech X530 speakers.
algae
916
Hi all,
I have to go over to my friends house tomorrow to help him hook up his new X530 5.1 speakers. He has a Dell pc with a SB Live Value card. He is only getting sound from 2 of his speakers. What is the proper configuration (which plugs to plug into, software config. etc. ) to make these work? Maybe you can save me some time when I get there.
Thanks much for any help.
Gary
Cdubneeddeal
7,473
They're color coded. However, the black goes into green. I'm not too familiar with the SB Live cards..are they 2.1? If so, he'll need to use the black adapter included with the speaks. If they are more than 2.1, then he'll have to go into his settings to enable the extra speakers.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
I think my old SB Live value was a 5.1 card.
A couple things
Is he listening to a source that is more than just stereo? Music should only come out two speakers and the sub. Try a game or DVD movie to see if the other speakers work.
Are all software settings on 5.1 speakers? Check the sound control program, the windows setting, and the game or player section to see if 5.1 is enabled.
If the card is indeed 2.1, then yeah the santacruz is a 5.1 card.
