Need help hooking up firewire
Slugbait
I have the Extreme Series Bad Axe 2 mobo mounted in a Thermaltake Armor. The firewire cable on the Armor is split into individual pin connectors. However, it has a white +12v pin connector labeled VP, which splits to a second connector also labeled VP. Then there is a black connector labeled VG, which also splits to a second connector labeled VG. None of the other connectors split.
Also, the mobo has TPA1 and TPA2, while the cable has TPA and TPB.
So, it's just a little bit confusing...wanna get it right the first time
I'm making an assumption on how the cable is to connect to the mobo pins:
Mobo layout: Cable:
TPA1+ (1/2) TPA1- | TPA+ (Blue) - TPA- (Orange)
Ground (3/4) Ground | VG (Black) - split VG (Black)
TPA2+ (5/6) TPA2- | TPB+ (Green) - TPB- (Red)
+12v (7/8) +12v | VP (White) - split VP (White)
(no pin) (*/10) Ground | (no pin) - Ground (Black)
Does this sound right? TIA
