Need Help. Having problem with fan on North Bridge Chipset of KT7-RAID
travisio
220
The fan on the north bridge chipset of me abit KT7-RAID is fluctuating, like speeding up and slowing down. It is very annoying. I know they that the fan is not necessary but I kinda want to keep it on. Is there a way to replace it? I took it off and cleaned it with a Qtip and put a little WD-40 on it. It seems to be working but every now and then it will do it. Basically is there a replacement fan I could get for it besides the one Abit makes? Also has anyone else had this problem?
gcliv
Banned
Oct 24, 2000
264
I have also had problems with chipset fan on KT7. Mine doesnt turn well and is real chunky sounding. The sound is awful so I had to take it off, its my parents machine and noises would make them nervous. They say that fan isnt really necessary, but my system heat has jumped 15 degrees. Its still well below too hot tho.
Pederv
1,903
Try a fan for a 486 heatsink. You'll have to replace the connector but it should fit.
travisio
220
Where can I get the blue orb and what size is it 40mm? I appreciate the info and if you could give me anymore that would be very useful.
lestat
i too would like to know the size of the north bridge fan on the kt7. im thinking of getting a 40 mm sunon fan to replace that madre.
thanks
ride525
1,379
Does the Blue Orb work and fit....it looks like it has two mounting holes instead of the four corners on the KT7 northbridge?
Any other recommendations?
Tonec
1,505
Using blue orbs on kt7s is a myth. The blue orbs doesn't fit. The two pin holes are shorter than the kt7 holes. Need tape or epoxy to make it work.
ride525
1,379
It's weird....I contacted ABIT and they said they wouldn't replace the fan underwarrenty.....the motherboard is only 2-3 months old......they consider the fan to be a "consumable"....
vfrjim
1,281
Doesn't matter anyways, in the new chipset, the fan was only needed if the FSB was over 137HZ, and I can bet that you are WAY under that. You probably could remove the fan and see no stability problems:).
Jim
