Need Help Have tryed Everything
mykah89
20
I purchased the pieces to assemble my computer the other day and i put them together
Athlon 3000+ CPU
Epox 8kda3j motherboard
Xtasy Ati 9200 SE video card
512mb kingmax ram
a Sony CD rom drive
a Maxtor 60gb hd
and this is the problem.. When i boot up the computer it goes to the Initial POST screen in which i have two options.. press F1 to continue or delte to enter setup.... i noticed at this point a 7F code in my LED box which means
(7F)1. Switch back to text mode if full screen logo is supported.
-If errors occur, report erros and wait for keys
-If no errors occur or F1 key is pressed to continue:
* Clear EPA or customization logo.
Not thinking anything about it or understanding what this code meant.. I hit F1 to continue and the code disappeared and turned to FF and everything was going fine,, now i continued on to load windows, windows loaded in great, well that is until it made me restart after the installation of windows, then it would go to restart and the screen activity light would turn a yellowish green indicating nothing was happening and FF would instantly appear in the LED Box.
(FF)-1. Bios chip inserted incorrectly
2. Incorrect BIOS update version I updated this so this shouldnt be the problem?
3. Mainboard problem
4. Add-on card inserted incorrectly all i have is a graphics card plugged in and the same thing happens if i remove it
I proceeded to reset the CMOS by moving the jumper over for 5-10 seconds and then putting it back. I powered back up and it went to the POST screen. This time instead of pressing F1 to continue i hit delete to enter setup. I tweaked a couple things such as the date and time. I go to save and exit the bios and it goes to restart.. where then i receive the instant FF again, and have to power down to reset the CMOS to get it to POST again.. I do that and it scrolls through the LED codes again and winds up at 7F again, so from the POST screen i reset it and it will come back up to the POST screen without me having to reset the CMOS. I sat down and thought to myself... Self.. what could the problem be.. so i pulled out the CMOS battery and tested it on a voltmeter.. yep its 3 volts... so then i pulled out the video card and booted without it to see if the 7F would go away.. nope still stayed... so then i went into the BIOS to see if upping the CPU voltage a bit would help.. nope nada, so then i tryed disconnecting everything but the hard drive and the power source as well as the CPU fan,, and that did not help.. so then i thought hey.. i have an idea,, i proceeded to Flash the BIOS with a floppy that i downloaded the bios to from the EPOX website i did that and then it asked me to restart.. i hit yes and once again i am rebooted to FF and a black screen,, this is really irritating me as i have been trying for days to get this to work. Any help would be greatly appreciated.
microAmp
5,988
110
I ran a Google search on the phrase "Switch back to text mode if full screen logo is supported" and from what I could tell from others with your BIOS error is that they had a bad video card.
Do you have another video card you can try? Borrow one from a friend? RMA the video card?
mykah89
20
Returned the Xtasy 9200 se video card, and got a Radeon 9200 instead, same problem 7F error and no boot without resetting cmos.
