- Sep 13, 2000
- 410
- 0
- 76
Just put in new MB and cpu. I think I have most bios settings in decent shape. When I put in the win me HD that I had been using before the rebuild it works fine, tests the floppy and boots to the HD.
I have a new larger HD I want to use. I disconnect the old HD and plug in the new one. It is found by the bios, correct size but as udma 33 not 66 as it is. I dont know if this is a problem, the hd setting in bios is auto.
When I start it up with a windows boot disk in A it boots up fine, but thats where it stops.
While at a> what do I do?? If I type format c: I get a response of invalid media . I cant seem to copy anything to c: Is there a set method I should be using because I am lost right now. Thanks for help RC
