Need help getting ethernet cable out of NIC
dullard
25,956
4,544
I need to move a computer and the ethernet cable is stuck in the NIC (built into MB). I've tried to pull as hard as I dare and it won't budge. I see the MB bending quite a lot under the strain, and nothing will move. Any ideas on how to get it out?
The cable must stay - I cannot keep it plugged in.
MichaelD
31,528
Are you pushing down on the little release tab as you pull the cable out? (Gotta ask) If so, possibly the release tab is broken and isn't really releasing the latch. Get a paper clip and unbend it. With the PC unplugged, use the clip to push inside and down on release tab as you pull the cable out. Wiggle if necessary. Works every time.
iamwiz82
30,772
13
you are supposed to hit the little clasp towards the cable to release the cable, just like a phone.
dullard
25,956
4,544
"Are you pushing down on the little release tab as you pull the cable out? (Gotta ask)"
Funny guys. ;)
"If so, possibly the release tab is broken and isn't really releasing the latch. Get a paper clip and unbend it."
The paperclip broke. Do you think that I should drive home and get a small flat screwdriver? Maybe thats a good excuse to do less work... Or do you have any other ideas?
Pepsei
12,895
or unplug it from the other end...
but since you said the cable must stay... i guess that's not an option is it?
MichaelD
31,528
Any small, flat object that will fit in there will do. Tip of a knife, penpoint, etc.
Viper GTS
38,107
433
<< Any small, flat object that will fit in there will do. Tip of a knife, penpoint, etc. >>
Bingo, use the tip of a knifeto catch the edge of the clip.
Viper GTS
dullard
25,956
4,544
<< or unplug it from the other end... >>
The other end goes through the wall, up one floor, to the locked server room.
I was having such a good day until this. In fact, I even was selected as a winner of several prizes including free info about Pres. Bush and free AOL for 1000 hours. But now, I'll use this as an excuse to go home for tools.
