For a friend:
I'd like to get a bigger overclock out of my CPU, but it seems I've hit a roadblock...here is my current setup:
Epox EP-8RDA+ w/ latest BIOS
Athlon XP 2500+ @ 2.2ghz (200x11)
2x512 OCZ Enhanced Latency 2-3-2-10
Coolermaster Aero 7 Lite HSF
I'm completely stable right now (Prime95 ran 11 hours with no errors/warnings) at 1.70V, and using nVidia's System Utility I can take the FSB up to 205, but at 206 my computer freezes.
Before doing this I lowered the divider on my RAM to 83%, raised the timings a bit, and raised the voltage to 2.77v just to make sure my overclocking problems weren't being caused by some poorly overclocking memory. I also raised the vcore to 1.775V, and considering that it's stable at 200fsb/1.7v, I'd think I could get past 206fsb/1.775v if lack of voltage were causing the problem.
My motherboard also seems to overvolt (do all 8RDA+s do this?); according to Speedfan and MBM5, my mobo overvolts from .2-.6 all the time, so 1.775V was the highest I'd take it for fear of high temperatures. At 1.775V and full load, Speedfan & MBM5 were reporting temperatures of about 53C, so temperature shouldn't be the problem either (is it possible that my board is reporting incorrect temperatures, and that it's much hotter than it is reporting? I doubt this though, because even at stock speeds and voltage I get around 40c full load, which seems pretty accurate.)
I know the EP-8RDA+ has a pretty crappy passive heatsink on the northbridge, but I'd think I could make it past 206fsb even with the stock heatsink...
Anyone have any suggestions for me, or is this my CPUs limit? I don't think it would be a motherboard problem (other than the northbridge overheating, perhaps) since the 8RDA+ is supposed to be a great overclocker...right? The multiplier is locked on my 2500+, I should add.
