Need help from Thinkpad owners.
SuperGroove
3,347
I have only 128MB of RAM. I bought this generic stick of 256MB of RAM that was CAS 3, pin144 SO DIMM, PC-133. When I installed it, my T23 would not boot up, but it would be several times then quit. It would not boot up after the beeps. The screen would remain unlit.
I was wondering if I could get away with buying non IBM branded memory. Perhaps some PC133 stick that is "compatible" with the Dell Inspiron 8100? RAM prices are crazy, and so is IBM. $31 for a 64MB stick? Give me a break!
What are my options?
Thanks,
Paul
RichieZ
6,551
40
Yup I've got a T21 came with 128, added in a stick of crucial 256. Works fine, you probably jsut got some junk generic stuff.
IBM does use good stuff tho, my original 128 is infineon chips
bozo1
6,364
I've used non-IBM memory in my Thinkpads before. The T23 Type 2647 wants CAS2 PC133, the Type 2648 wants CAS2 PC100 - maybe it doesn't like the CAS3 - I've found IBM stuff to be very picky about using the exact rated stuff.
Crucial has the PC133 256MB for $84.99, $67.99 for the PC100.
salsal
168
crucial.com will find the right memory for you. Use Anandtech 15% discount. Free shipping too.
SuperGroove
3,347
<< crucial.com will find the right memory for you. Use Anandtech 15% discount. Free shipping too. >>
Crucial is expensive:( $85.00 with 15% off. It stinks. I want generic RAM!:) I just want to know if it will work.
andrey
I'm using 2 x 256MB sticks of Crucial SDRAM in my Thinkpad T22. Works beautifully!
As far as getting away with cheap RAM, 99.9% of the time you're getting what you pay for. If you're concerned about your system stability, dont' even think about no-name generic brand, you can see from your experiece what happens.
