I am living in a new place with roommates that I don't know very well... I use the 'switch user' menu option off of the Logoff portion of the Start menu, which takes me to a login screen requiring me to enter my password to regain access to the desktop. It also allows processes to stay running so I can instantly pick up where I left off after logging back in. I do this to secure my box if I am expecting to be not within sight of my computer for a certain period of time while roommates are around... To my dismay, the other day, I was in another area of the apartment for a little while... when I returned and checked my screen (the login screen), I saw a pop-up message I've not seen before... There's a logoff button at the lower left corner of the login screen... when you click on that button, you get a blue pop-up at the center of your display, with 3 options: sleep, restart, shutdown... before I left my computer I had selected the 'switch user' option and it took me to the login screen, which should have secured my computer.. when I returned to my computer, I saw a different looking pop-up message... it was more rectangular than the aforementioned blue pop-up, and if I remember correctly it was grayish colored... it asked if i wanted to either restart or shutdown.. i don't recall exactly.. i just remember that the pop-up looked foreign to me.. if i had simply seen the aforementioned blue pop-up.. i would have thought maybe i clicked the logoff button by accident before i left.. but since this is a new pop-up i've not seen before, I am wondering if a roommate was tampering with my computer while I was relatively briefly away.
Could someone familiar with XP tell me what this pop-up screen may be? and how it can be triggered (I tried a variety of hotkeys at the login screen to see if I could make it happen again, without success)? is there a way to check to see if someone may have been fiddling w/ my PC while I was away? logs of login attempts or whatnot perhaps?
I want to find this out to determine how much I can trust the new roommates. Thanks in advance.
