need help from Samsung 955 DF owners...
nny
i'm thinking about buying a used 955DF from a friend. I'm using it now and it looks fine, but i noticed there are 3 pins missing from the jack. is this normal? is there a way i can find a picture of the pin layout to make sure this monitor hasnt been damaged?
yah, the VGA connector. I'm seeing a total of 13 pins, but the last one on the 2nd row is halfway pushed in. is this normal?
Mine has 13 pins. If it works and all the controls function properly, you're good to go. Don't sweat it.
