Need help from physicists .. electrical engineers? haha
desiplaya4life
1,449
stupid question, but i need help so i thought i ask my fellow ATOT's
we have a dishwasher at home that I want to use but my mom insists not to because she complains it uses raises the monthly electrical bill sky high. For i disagree with her statement. So i am pondering now how much electricity juice does our dishwasher actually consume with the following stats:
Motor draws: 5.2 Amps
Heater: 4.4 Amps
TOTAL CURRENT: 8.6 Amps
(According to its label)
Electricity current rate: .15805cents KwH
We use it once a nightx7daysxfor and it runs for 1hours. in that one hour, only 30mins it is, that the heater turns on and does its job, offcourse.
so how much extra would that churn out into our monthly electricity bill?
Thanks guys.
Mark R
16
The amount of energy a dishwasher uses varies with model and program.
But a fairly typical European model, running a standard wash program uses about 1 kWh of energy. So that works out at $0.16 per wash.
magomago
10,973
14
i'm not an EE but,
Energy = integral (v*i) dt
we see that the i_motor and i_heater is constant
to figure out the power you need to know the voltages they run on...would it be 110V out of the plug? I have no idea
but in any case the voltage and current will be constant
then v*i=constant and draw it out and power is simply
Energy=v*i (T2-T1)
where T2 and T1 are in seconds
so you'd plug [30 minutes *60 seconds] else you'll have unit dimensional issues. You can take T1 as 0 in this instance since we can take the time of reference as when you turn it on
I also divide by 1000 to give us Kilojoules instead of just Joules
sooo
Energy_motor= v*i_motor *30*60/1000
and likewise
Energy_heater=v*i*30*60/1000
edit for stupidy ;) told you i wansn't an EE, but atleast it caught it b4 u guys yelled at me
although actually you just need to find the power (again i'm assuming that junk is all constant)
Power_x= V_x*I_x/1000
where "x" is either motor or heater
and then multiply by .5 since its running for 30 minutes
and then do
.15805/Power_x and that is the cost for each portion
magomago
10,973
14
Originally posted by: desiplaya4life
mannnn that just went over my head..
focus on this part
Power_x= V_x*I_x
and then do
So
Power_Motor= Voltage_motor * Current_motor (units here should be in J)
Then Energy Motor uses = Power Motor *.5 /1000
then total cost: .15805/ The Energy Motor Uses
TankGuys
1,080
Assuming your dishwasher runs @ 110v (I'm tired, and can't remember if they are 220v standard off the top of my head)
Power = Voltage x current, so the power you use is 110v x 8.6 amps = 946 watts.
Assuming you run the dishwasher for on hour per day, thats 7 days x 1 hour x 946 = 6622 watt/hours = 6.622 Kwh
Total price for a week of operation = cost / kwh * kwh used = 15.8 cents * 6.622 kwh = $1.04 per week.
So, there you go. Unless I'm too tired to think straight, it would cost you ~$1.04 each week to use the dishwasher.
Special K
7,098
First of all, that assumes the current draw is constant throughout the entire cycle.
Second, what about the power factor of the dishwasher? Unless the current and voltage are exactly in phase, you can't just do P = VI.
Maybe I'm overcomplicating this, but I've seen applicances with power factors listed, so I figured it might be an issue here.
Fenixgoon
33,690
13,412
don't forget that you have AC current, not DC, unless the washer has an AC ---> DC transformer :)
also depends on how the motor and heater are arranged the circuit - your conditions assumes they are in series, and you'd have to account for the voltage drop, no?
assuming voltage and current are in phase, can you use the Vrms? (which is roughly 77V for 110VAC)
<--- engineer, just not EE, so circuit analysis is still a bit of a mystery to me :p
WisMan
546
Wouldn't a power factor of say .8 or whatever a dishwasher would be just lower the amount of watts it uses? Making it cheaper?
I seem to remember Actual Power (Watts) = Power Factor x Volt Amps
AlienCraft
10,539
some heating elements come on to heat the water pre wash too. Ours does.
There are logging meters one can use to actually document the load draw under use. I am familiar with old school analog models (think loong strips of paper) but I'm sure there is one than can be accessed via a network IP address.
Maybe see if there is someone the power company can refer you to that does energy audits for their commercial customers.
Special K
7,098
No, the lower the power factor, the more reactive power the appliance uses. Reactive power doesn't actually do any work, so consuming lots of reactive power is not a good thing in this case.
For anyone who has any EE background, I find the following discussion of complex power to be pretty good:
link
LS20
Banned
Jan 22, 2002
5,858
Go to Sears, check out the energy consumption tag (every home appliance has one) that has estimated yearly operating cost. probably somewehre in the neighborhood of 50-100$ a YEAR. so less than 10$ a month
Colt45
19,720
110/120v AC is stated as RMS already
peak is like 165 - 170v
hanoverphist
9,867
23
we know its going to be less than a couple bucks a week, so if thats worth arguing over, take the thing out and tell her to burn some old fashioned calories doing the dishes. the easy route would be to look up the dishwasher on the manufaccturers website and get the energy info there, or open it up and get the fla of the motor itself and the draw of the heater element. youll also have to take into consideration any moving parts (mine has an extending arm that sprays the top rack too) when figuring out the draw. but again, none of this is really worth it when youre talking a buck and a half a week.
