I posted this before about a year or so ago. However it is happening again with my new install of Win2k.
I can?t remember what the fix was, but someone posted a fix for me the last time I posted this same problem (I hope that person is still around).
Basically the problem is whenever I go into control panel I get an: ?"explorer.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created"
The only thing I remember was that it was a very simple solution, I can?t remember if I had to shut off something or uninstall a program or if it had something to do with my High Point drivers?
Thanks for your help!
