Just installed two Quantum LM30 disks on an Abit KT7-RAID and I was trying to format the C: partition (Fdisk'ed first). When I try to enter the format command (after booting into DOS from startup disk), the C partition counts up to 100% on the format step, then stops dead while displaying:
Writing out file allocation table
0 percent completed
At this point, the 'puter locks up hard (no Ctrl-alt-del available) and must be reset to continue. Any ideas???
Thanks
BTW - Although capable of running faster, I have the Tbird set at the stock 800MHz for this procedure.
0 percent completed
Thanks
