Need help for OCing
McArra
Hello all. I've got this rig:
AMD64 3000 90nm, MSI K8N neo 2, 512 Kingston PC3200 CL3, ASUS V9999GT 256mb (6800GT), Seagate 2x120gb Sata 8Mb, Audigy 2, Zalman 7000A al/cu, NEC-2500 8x DVD-RW, TT purepower 680W
My problem is as following. I have a CH5 module installed in the 3rd slot, set to 133mhz and 2.65V (timings: auto and 3-3-3-11 whn manual). The HTT is @3x, core is with 9x multiplier and 1.5V and I'm using locked SATAs near the CPU. Every time I try to raise my FSB to 250Mhz windows shows me a blue screen and restrts, and if I try it through BIOS (v1.4) system won't even start :bang:. Am I doing something wrong? Anyone can help me?
Thanks in advance
Ok, looks like somebody else is having the exact same issue with this MoBo memory combo. Any known issues between CH5 chips and K8N neo 2??
