100 dollars... Ok it will be not a problem.. Btw i will use my laptop to play like battlefield, assassin cread, nfs mw(2012) etc games... So for these games which one will be suitable plz tell me... Buying country - India.At this price point I'd say that you'll have to compromise on one(maybe two) of the following parameters i.e.
display, CPU, GPU, SSD
Personally I would go for a 1080p(or higher) resolution display which can increase the cost on a given model by 100$ or more, depends on the base config, also you should mention your own preferences in terms of the four parameters listed above & from where would you be looking to buy this laptop, as in online or not btw country as well.
You might want to check out lenovo outlets or keep an eye out for their Y500 series which often times comes with dual 750m which will be your best bet if you're looking for 750 price range.100 dollars... Ok it will be not a problem.. Btw i will use my laptop to play like battlefield, assassin cread, nfs mw(2012) etc games... So for these games which one will be suitable plz tell me... Buying country - India.
I don't think you've understood what I was saying but for gaming see this particular model ~100 dollars... Ok it will be not a problem.. Btw i will use my laptop to play like battlefield, assassin cread, nfs mw(2012) etc games... So for these games which one will be suitable plz tell me... Buying country - India.
www.ebay.in/itm/231084225204?_trksid=p2057890.m2703.l3
What games are you trying to play exactly? It varies from game to game but on a 7650m @ 1366x768 you should be pretty solid on most games.what about this laptop..!!
http://www.flipkart.com/hp-4540s-pr...id=COMDHAQ7GZTCXCRR&otracker=search&pageNum=3
games like battle field, assassin cread, nfs, call of duty etc... I want play in it..What games are you trying to play exactly? It varies from game to game but on a 7650m @ 1366x768 you should be pretty solid on most games.
