my mobo temp is about 31-33C, a little high, right?
i know the usual way to cool a case is to put a intake fan in front, and an exhaust fan at back, to create airflow. but the problem is that my case doesn't have a place at the back for a fan, not even a place to put a hole for a 80mm fan.
so what can i do? (other than replacing the case)
should i put an exhaust blower at the pci slot? then it'd be UNDER the cpu, won't help much i guess.........
is the intake fan alone good enough to create airflow?
PLEASE.......HELP.......ANYONE?
