Here is where I got mine for a Alpha P3125.
60mm to 80mm/92mm fan adapters on For Sale/Trade Forum
The construction is a little flimsy, but then again, mine was a beta. A bit of duct tape fixed it quick.
The advantage is the ability to use a larger fan to get the same CFM, but less noise. 80mm seem to have the best CFM to noise ratio out there.
Now after a certain point, you run into diminishing returns with larger fans. A 92mm or 120mm may give you more CFM, but it fails to gain you anything else in cooler temperatures or in o/c. Where that point of diminishing returns is located varies somewhat. However, looking at overclockers.com, it seems that the difference between 33CFM and 38CFM on a PEP66 is negligible.
That being the case, an ADDA 92mm @ 41.6 CFM and 30 dBA would be a good choice. That kills the Delta 60mm @ 38 CFM and who-knows-what in the noise department.
For my Alpha, with two fans, then two 80mm @ 26 CFM and 23 dBA (or 52 CFM total and 26 dBA) works just fine.
Make sure that there is room in the case for the larger fan.
