need help flashing radeon 8500 bios!!
saltedeggman
3,775
I have the utility program, but when i ran it after swapping out the bootable disk, it said wrong ms-dos version
darktyco
122
I shudder to think what your other 807 posts were like.
Anyway, the problem is the way you are using your disks. I know the flash util takes up a lot of space, but with the removal of certain files you can get it to fit right on the boot disk. Once you do that your problem should be solved and you can flash away.
