- May 28, 2001
- 197
- 0
- 76
I have a VisionTek Theater 550 and I'm currently using PowerCinema, which works fine, but what I would like to do is connect my Gamecube so I don't have to use my roomate's TV which is constantly on sports channels. The problem is that PowerCinema always saves the incoming signal to the hard drive before actually displaying it so there is a huge lag period from when I press a button and when it actually displays. I've tried a few other options such as ChrisTV Lite, K!TV, DScaler, and more, but most of them don't support the Theater 550 chip and crash when I try to use them through WDM. ChrisTV works fine with my tv card, but it wouldn't let me select the option to select composite as the incoming video signal. So basically what I'm looking for is a TV program that is compatible with the Theater 550 chip, has no PVR functions or lets you disable them, and lets me use composite video as the signal.
