need help finding the best case for my needs, OC
Infuzia
4
oky this is the deal,
im looking for a case+PSU for my new rig:
E6400
Asus P5B DLX
Memory corsair DDR2 1066mhz XMS2 8500C5 1024x2
HS- Tuniq tower 120 ( yeah we got it here :) , how sweet it is! )
hd - Samsung 80gb IDE 8buffer
DVD-rw LG
video card- for now i will have something lame (x300/7100/7300/6200)
i'll wait for the mainstream DX10 cards.
im planing on OC the CPU and probably the future VC
i wanna get the cpu to 3.6ghz+
i got couple of choices for case+PSU
1. Antec P150 + his PSU the antec Neo HE 430W ,i can get is for a really good price- 150$
2. Compucase 6C21/6920 + enermax liberty 400W - 155$
3. Gigabyte Posiedon + enemrax lib 400W - 195$
4. Centurion RC532 COOLERMASTER + enermax lib 400W - 190$
5. if u got other suggestions i will be happy to hear them.
Baked
36,052
17
1) Nobody knows where you are.
2) You're gonna need more than a 430W for a DX10 card.
3) You're gonna need a big ass case to house a DX10 card.
4) Antec P190 + Seasonic M12 700W
Boyo
1,406
Agreed on the amount of power you are going to need to run a DX10 card. Read some articles on what those amounts are. I would go with the Enermax Liberty 620W. Case is a matter of personal preference. I like Lian Li's cases.
Infuzia
4
1. if you need to know, im from israel
2. im planing buying the mainstream DX10,
they wont be big like as high end DX10 , im planing getting the "8600"
3.if the 7900GTX can fit this cases i guess the "8600" can fit too.
4. its 600$!!!!! case 300$ psu 300$!!!
my budget is around 150-170$
Lian Li's cases start here from 270$ for the simple
and 500$ for the good cases.
"Case is a matter of personal preference" not only , every case got diffrent preformance,
i wanna the the best case+PSU for my budget,
i need an case with a very good airflow, so i could rich a higher OC speeds.
and keep the components as cool as they can get.
Skott
5,730
Supposedly the new 8800GTX is 10.4inches long so bear that in mind when choosing a case. Some midtower cases wont allow for that. nVidia is supposedly reccomending a 450w psu although 400w will probably cover it if its a good quality psu. I'd go with nVidia's reccomendation though just to be on the safe side.
Baked
36,052
17
How can the Antec SLK3000B be more expensive than the P150? The former is like the cheapest case in Antec's line-up. Well, if you're stuck w/ the options in your list, I would get the P150. Got a pretty good review from SPCR.
Infuzia
4
its a "second hand" P150 so its cheaper
new p150 cost around 240$
