Need help finding Slot 1 motherboard...
SeeET
28
Hey everyone, my friend just burnt out her motherboard and is desparate need for a new one. Unfotunately, it seems incredibly difficult to find Slot 1 motherboards for her processor. She has a Pentium III-850MHz slot 1 processor. Does anyone know a place that sells a motherboard that supports that kind of processor? I'm looking more for speed and price rather than features or overclockability. Also, it'll need an AGP slot. Any suggestions? Thanks!
DaveSimmons
40,730
670
I still see Tyan mobos with slot+socket listed at newegg and/or google. Other choice would be to sell the 850e (check eBay selling prices) and get an Asus TUSL2-C + Celeron 1.2a for about $160 from newegg (less whatever the 850 brings).
[edit] Also some used ones in FS/FT forums here, under $50 -- Abit BE6-II and BF6 are good ones. I have a spare BF6 myself but haven't had time to find out whether the cold boot problem it has is caused by the mobo or the old Maxtor drive I used with it.
PeteAair
24
Justdeals has a good selection..They have some Gainward Slot1 boards for Cheap Bx and Via chipsets. Heres the Link..Gainward is a sub of Soyo.. Hope this helps.....
blackhawk
2,690
The only new ones I still see once in awhile are the Tyan 400's which I once owned. Good stable mb with very little overclocking features but has both socket 370 and slot 1 onboard. The slot 1 I used for over 3 years was an aopen ax6bc which you can find on the used boards once in awhile. Used is your best bet
Zap
22,377
7
SeeEt, if your friend absolutely still needs a slot 1 board and y'all can't find one anywhere, LMK and I may be able to hook you up.
