It's a Dell Optiplex (I have for work) and I have:
i7 2600
16 GB DDR3 1333 Ram
OCZ Vertex 3 MAX IOPS SSD on SATA 3 Intel header running at 550 MB/sec read/write speeds
Seasonic 650 X Series Gold power supply
Two 1 TB WD Black 64 MB cache storage HDD's
NEC PA 271W 27" monitor
NEC 3.0 PCI card
One pcie 16 2.0 slot
and one PCIe X4 slot
Frankly I dopn't do much gaming but want a great card so my options are open. Problem is length. I have 9.5 inches in length max for the card. With some cable moving I "might" manage 10 ' but that's kind of pushing it. Yes, the case takes full height cards.
Also, the cooler it runs the better since this case is obviously not designed for high end gaming and the necessary cooling for what I'm creating.
I also want 2 DVI dual link and two display ports minimum.
Thanks.
i7 2600
16 GB DDR3 1333 Ram
NEC 3.0 PCI card
Thanks.
