Need help finding parts for building a small computer
PhoenixOfWater
1,583
Hi I am plan on building a computer and the case too and I want to make it as small as I can but I need some help finding the right stuff? First I need a small Mobo and then CPU with a small Fan on it? then a small power supply?
I think I would ?like? a Mobo that use the Tualatin Celeron and DDR Ram (if they have that) and have everything (LAN, Sound and Video) on the Mobo and if I can I would like to overclock the CPU up to a FSB of 133+? The Mobo have to be small? I?m not planning using any PCI slots (if everything on the Mobo) oh is there a way to make AGP card be plug in horizontal to the Mobo?(if so then I wouldn?t need video on the Mobe) Next I need a small power supply? all I am planning on running off of it is the Mobo and 4 to 5 fans 1 HD and maybe 1 CD drive or Disk drive.. so I think 250 watts would be good right? Ro do I need more? but I need it to be small? find a small CPU will be EZ (i think) i picked the Celeron for i wouldn't have to deal with the much heat...what do you guys think...
I thank you for any help or ideas :)
