Here are the full RAM specs:
| Product Name / Series | G.Skill Trident Z RGB |
| Model Number | F4-3600C16-16GTZRC |
| Type / Freq | DDR4-3600 |
| 3600MHz (XMP1 Profile) | CL16-19-19-39-85-1T (tCAS-tRCD-tRP-tRAS-tRC-tCR) 1.35V |
| 2132MHz (Stock Profile) | CL15-15-15-36-50-2T (tCAS-tRCD-tRP-tRAS-tRC-tCR) Auto: 1.20V |
| DIMM Configuration | 4 DIMMs, Each 16 GB |
| Installed DIMMs and Total RAM | 4 DIMMs, Total of 64GB RAM |
| DRAM Manufacturer (According to AIDA64 Extreme) | SK Hynix |
PassMark Overview Page for my kit.
I've searched high and low on google for my RAM model number
F4-3600C16-16GTZRC to find out as much information as I can, but there is next to nothing on google for this kit.Does anyone here own this DDR4 kit and know the exact die? AIDIA64 Lists the manufacturer as SK Hynix, and the DIMM density is 16GB per DIMM. So that should mean the first portion of my Die is
H16.I'm trying to avoid taking out my DIMMs to find out the die revision. I will if I have to, but hoping someone knows already.
This forum link was the most helpful so-far, with users reporting about the
F4-3600C16-16GTZRC. One posted said "You are likely to be Hynix D-Die Dual Rank".So if that poster is right, my complete Die should be
H16D. But unfortunately - I don't know if that poster is correct.Anyone know the die revision of this kit, and if AIDA64 is correctly reporting the manufacturer as SK Hynix?
Could really use some help!
Thanks so much,
Jay
