There is a road out there that has one small problem, a large outcrop of just the right shape to block my FJ. Once past the outcrop the road is good for many more miles. I tried to crawl over the outcrop and concluded that unless I develop a taste for the bumperless look, geometry and physics have conspired to keep me a pedestrian.
A light bulb came on (dim as it might be) that I might be able to ramp over the outcrop using well, ramps. The trouble is finding a set of ramps that can support the weight of the FJ (~5000lb), ~10ft long, and are light enough to carry on the roof rack (<150lb), light enough to be lifted by yours truly, and not too expensive.
Another choice is to break out the shovel and bury the outcrop. This tends to annoy folks who like obstacles and would require many an hour of labor. I might even sweat.
Anyway, if anyone has a lead on where to obtain such ramps I would be appreciative and vow that if I should ever have an opportunity to put this plan into action that a youtube video would be de rigueur.
