I had to reinstall windows xp on an old HP Pavilion 742n machine and got all available drivers off the HP site. Well the Ethernet driver is no where to be found. I can't figure out the MB maker I thought I could go to their site to look.
Well looks like Ma-Config is useless if I can't get the Ethernet drivers first since it posts it's results on it's web page. Not sure if it will work offline but it didn't this time.
