phlashphire
Bought this thing a while ago, and lost the drivers cd. Maybe someone here has the drivers?
I looked through driversguide.com and google, and www.usb-drivers.com and was unsuccessful.
Text
Wrote to comgeeks, and got this response from,
"Sorry to say but you are out of warranty with this item and we will be
unable to assisted you with any service or support from this point on with
this item!
Thank you for using Tech Support at Computer Geeks"
Kinda irrates me, I'm not even asking for much of "warranty support"... just drivers they probably should have.
Features/Specifications
General Features:
- External Case which Supports 5.25-inch IDE Devices
- Converts IDE Devices into USB or FireWire Devices
- Compatible with PCs and Macs!
Testing has Determined the Following Drives to be Compatible with this Case:
- 5.25-inch Hard Drives in USB or FireWire Mode
- 5.25-inch CD-ROM Drive in USB or FireWire Mode
- 5.25-inch CD-RW Drive in USB or FireWire Mode
- 5.25-inch DVD-ROM Drive in FireWire Mode ONLY
- 3.5-inch IDE Hard Drives in USB or FireWire Mode, though a longer IDE cable
-- is recommended to permit proper mounting of the drive.
Testing has Determined the Following Drives are NOT Compatible with this Case:
- 5.25-inch DVD-ROM Drive in USB Mode ONLY
Technical Specifications:
- Compliant to USB Specification Revision 1.1 and IEEE 1394A (FireWire) Standard
- 100% Plug-&-Play Compatible
- Three (3) IEEE1394A (FireWire) Ports
- One (1) USB 1.1 Complaint Port
- Left and Right Composite (RCA) Audio Jacks
- Up to 400MB per Second Transfer Rate using FireWire Ports
- Up to 12MB per Second Transfer Rate using USB Port
Chipset:
- Oxford Semiconductor OXFW911-TQ-A / RealTek RTL8801 Chipset
Package Includes:
- USB/FireWire 5.25-inch Drive Enclosure
- One (1) USB A to B Cable
- One (1) IEEE 1394 (FireWire) Dual 6-pin Cable
- 100 - 240V Power Brick Supply and US Power Cord
- Drivers on CD-ROM
Any info would be greatly appreciated.
Text
this item!
General Features:
Chipset:
Package Includes:
- Drivers on CD-ROM
