Need Help Finding Compatible Ram
rocafella504
I have a ASUS M2N-E Socket AM2 NVIDIA nForce 570 Ultra MCP ATX AMD Motherboard. I'm looking for a 2 x 1gb dual channel kit. I just want to see what is compatible with this motherboard. I have read reviews about people complaining that their ram will not work with this motherboard due to voltage issues. If anyone can help me, I will appreciate it a lot.
Originally posted by: johnno
TWIN2X2048-6400(fixed link)
Will probably be trouble free, and it's tested at 1.9v.
The RAM posted above is tested at 2.1v which is above the boards max.
The ram I linked is on the motherboard's qvl list(tested and approved by asus themselves for compatibility). For some reason asus has three separate qvl lists for each ram speed zipped into one download on the motherboards info page, generally for most other boards they put all of the speeds and approved ram in one download and do not compress it.
