Need help finding an HDTV ASAP
ss samy
I was looking for a cheap reliable HDTV. I live in Canada. I think this one is Ok but it doesnt have 720p. It has 480i, 480p, 960i, 1080i. I plan to use it for gaming on Wii but maybe also ps3 if my friend brings it. Will it be ok?
http://www.futureshop.ca/catalog/prodde...08&catid=23520&atab=3&logon=&langid=EN
Can anyone rate the above TV? (my parents distrust LCD a little bit...)
I need an answer ASAP because we will buy a TV very soon. (upgrading from 15 yr old a 24" JVC tube.)
Are you sure it doesn't support 720p? Right now, PS3 is having trouble, some games won't output in 1080i (lack of a video scaler maybe, so it has to change resolutions like a PC?) so your next choice is to drop the res down to SDTV res.
Originally posted by: ss samy
can you tell me how because i downloaded the file and it won't open!!!
If it can accept 720p, you don't need to do anything differently, just plug in a 720p input and it will work and scale the input to 1080i.
