Need help finding a VESA mount
Galatian
372
Hey,
I'm having trouble finding a fitting three monitor VESA mount for my desk. I currently run one Korean 27" 2560x1440 panel and I'm so amazed by it, that I want to order two more and have them all on a VESA mount. They use the 100x100 cm VESA mounts. The screens are 66 cm wide. Most triple monitors VESA stands for desks support only smaller sizes (I found a triple monitor mount from NewStar, but although it states up to 27" the outermost stand only go to 1290 mm, which should - if my math is not completely off - not fit).
Does anybody know where I can find a good triple monitor VESA mount that can hold my screens or should I just stick with 3 single monitor VESA mounts?
JBT
12,094
I don't see any three monitor mounts. Two's and fours yes, but not three :(
Zargon
12,218
I have a tyke supply/easymountlcd.com mount, I am not sure it will fit 3x27"
I have 2 Korean 27's and a 23" on it now
