- Jan 23, 2007
- 1,149
- 0
- 0
I'm looking for a good UPS for my PC. I'm using an APC 550VA now, and just ordered a CyberPower 1500VA because of the great reviews and features.
such as:
http://www.hardwarelogic.com/n...E/1376/2007-05-11.html
http://benchmarkreviews.com/in...sk=view&id=82&Itemid=1
However after placing my order I discover a review on newegg with a reply by the manufacturer (see below). I've got a PC using an Antec NeoPower 550Watt PSU which does Active PFC. Will this thing still work or should I go return it when it arrives.
How important is finding a PSU that produces a true sinewave? I've got a 42" panasonic plasma TV as well which is why I wanted to upgrade, but how will this affect that?
Thanks for any help, and if you have any suggestions about what UPS I could actually get that would work that would be wonderful. Preferrably something at Bestbuy or Staples
so I can return it if it doesn't work out.
Pros: works well with Linux
Cons: very bad power output - not even close to a sine wave...
as a result, 2 out of the 6 computers I tested on it don't work. One has an older Antec TruePower 550, the other a Rosewill 650W power supply. Rosewill one doesn't power on, the Antec one doesn't find the sata dvd drive and crashes often. When run on street power or off an aging APC unit, they both work great.
Other Thoughts: Comparable APC units are not much more expensive - don't make the same mistake I did and hope you can save yourself a few bucks...
Manufacturer Response:Thank you for your comments on the CP1500AVRLCD. In regards to the UPS not outputting a ?true? sinewave, you are correct; the output waveform of this device is a simulated sinewave. Computers which utilize a PFC (Power Factor Correction) power supply will only function correctly with a Sinewave UPS ? which can be found in CyberPower?s Professional line of UPS systems. Most mainstream PC?s on the market do NOT have PFC power supplies, so these UPSs operate flawlessly under typical conditions. Thank you for your feedback, and sorry for the confusion. CyberPower Systems.
such as:
