Need help finding a tupperware or other hard plastic case
StageLeft
70,150
I need a long square plastic case, preferably with a handle to carry something very special. Unfortunately, the closest tupperware I've found (no handle, but that's ok) was only 40" long and not quite high enough. It was wider than I need, but that's tolerable. I think perhaps a gun case would work, but they're too expensive. I'm really looking in the $40 and under range. Walmart, lowes, hd, linens & things I've all checked.
In fact, come to think of it, I bet the case that those rocket launchers we see on movies would work. This isn't a rocket launcher, but something similar (I mean the case, this doesn't have explosives in it). Are these easy to come by? They even have handles.
StageLeft
70,150
Hmm, maybe I should look for a local store, that might work. I've thought of building a box, too, but it could turn into a bit of a hassle although its dimensions would be ideal.
vi edit
62,484
8,345
Maybe check a used sporting goods store for a hardshell golf club carrier.
Might be a little bigger in each direction, but pretty close.
daveymark
10,573
Hmmmm...tupperware party at Skoorb's? haaaaay! I'd need to know more about the contents of the contraband in the case so I know which tupperware models to demo. for instance, if it's fresh contraband, the container may need to be burped every few months. There is a revolutionary new feature on some of the lids that allow a simple twist of the knob on the lid to burp. others have buttons you can press in, etc
StageLeft
70,150
Yeah :( I can picture it now. The thing was on the ground at a yard sale two weeks ago selling for a song, a beige carrier. I don't know that it would have been long enough but dimensions would have been close.
This is for an RC plane. I want to build the wing as a single piece, hence the long length
