Need Help Finding a Replacement for a Blown Skullcandy Air Raid Bluetooth Speaker
Hotrod123
One of my Skullcandy Air Raid speakers is torn. The manufacturer doesn't make this speaker anymore and doesn't repair them. I searched all morning for a replacement speaker but not sure which one to get. I believe the speaker is a 2"inch 4 ohm 5watt neodymium full range speaker. It has a number on the back of 1415 but I tried to google it as a part number and had no success finding it. I looked at 2"inch 4 ohm 5watt neodymium speaker images on google and again no luck. My questions are:
  1. Does it matter if I change both speakers from a neodymium magnet speaker to ferrite magnet speaker other than weight?
  2. Would there be any negative issues if I went with a 10 watt speaker vs the 5 watt speaker that originally came with my unit?
  3. Do I need to get the same style speaker with a solid diaphragm/cone or can I use one with a cone in the middle. The original speaker sounded great so I don't want to change the style if it's going to change to sound but I haven't found the same speaker yet and might need to get an alternative speaker
Thanks
sdifox
100,860
18,078
Try parts express. You need to measure screw hole and dimensions and stick to 4 ohm. Power handling doesn't matter much as long as it is bigger than original. Honestly I would just try to glue it with silicone. It is not worth fixing, Skull Candy sells garbage. Drivers all sound different so you do need to replace both.
Example
Compared to
