Need help finding a PSU
REDtoLINE
95
I was hoping to buy this case:
http://www.newegg.com/product/...x?item=N82E16811154087
and I have done many google searches trying to find a PSU to fit this case. From the picture of the PSU specs, I would assume it's TFX. The AMEX website for the case says that it's an SFX PSU. But the page for the actual PSU says it's Flex. I am so confused and it is impossible to find a small PSU over 300W let alone one that will fit this case. Any help finding a PSU that FITS and is over 300W would be greatly appreciated because I am so lost. Thanks.
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
TFX is the "Thin" form factor. It is not the same as SFX.
You really can't get anything with more than 300W due to the small size of the unit, but you can get a better QUALITY unit that might actually be able to put out 300W for long periods of time. Both Enhance and FSP make TFX power supplies for around $30.
If you have to have this case and plan to run a high end graphics card or cards, I suggest adding a second 5.25" bay PSU to the mix, something like the Ultra Power Partner or FSP BoosterX, to power the cards.
