Need help finding a part
Status
Not open for further replies.
slag
10,473
I was given this structure:
and I'm missing this part:
Where can I get it? The tube going into it appears to be 3/4 inch.
Thanks,
Slag
CZroe
24,195
857
What is the structure for? Hanging clothes? Monkey bars?
Is it aluminum, steel, or what?
dougp
7,909
4
Angled Y adapter in the plumbing section at Home Depot.
Actually, if that doesn't work - go to a sporting goods place with a camping section, they might have replacement elbows there. I'm assuming that's a canopy frame?
CZroe
24,195
857
I was researching a canopy for my car when I saw the thread so that was the first thing I thought of but, if it's a type of monkey bars, I don't think you'd want to use a fitting made for only holding up canvas + frame.
slag
10,473
I was at a boy scout committee meeting and a troop had some old gear they were throwing out. This was in a bag along with the top cover. It is missing all the bottom legs but I can make those easy enough. Looks like its just your ordinary older sun shade, however, I'm missing one of the corners. Its skewed at an angle, so a normal 90 degree 3 outlet fitting won't work. I went to home depot and Ace Hardware and none of them have an angled corner adapter like I need. I did find a metal one, but it was for 1 inch pipe and this is 3/4 inch. Could adapt it, but still, would rather have an original piece. No idea how old this is.
I was thinking I could use my bandsaw and cut a chunk of wood out that would work, but would rather not do that.
BoomerD
66,282
14,703
Status
