Need help finding a new/better ISP
Hi all, im currently using Verizon DSL at 768down 128up ($50/mo) and im craving a LOT more upload bandwidth, preferrably 384k+. My problem?
The providers here suck bad. I can get:
Adelphia powerlink (they only offer a shared package according to their sales rep, no dedicated bandwidth like some providers).
Verizon which offers a 1500k/384k package at $70/month. My only problem with this is they require me to use a program called winpoet that i hear is buggy and requires you to connect to it. So you lose the "always on" connectivity of DSL.
Edit: I found out that winpoet is not a concern as my router supports PPPoE.
Stargate which works through verizon and offers the exact same packages with far worse tech support.
Can anyone help me find a provider for under $80/mo that can provide me with 1.5m down and 384 up or faster? I'm in Erie PA, and the phone # of a nearby store is (814) 838-2113 if you need a sample number. Ive looked around and this is all i could find 🙁 hopefully someone here knows more than i do.
Thanks in advance for any help 🙂
You can get a new IP by resetting your modem.
Seriously ... I'd say Verizon and throw a FreeSCO box in the way to hand the always-on bit. Their latest build 0.3.1 has PPPoE support for almost every provider.
- M4H
- M4H
FreeSCO looks pretty complex... is it easy to use?
verizon's new modem handles the PPPoE for you. Plus. there's a HD thread on a free upgrade to your service.
Current router is a Linksys Etherfast Cable/DSL 4 port.
I believe it does have PPPoE support.
So i wont need this software?
My only lasting question then is there any way i can get access to a cable provider other than Adelphia. Or is it like DSL as in i have to be near a "hub" in order to connect.
Im far more interested in haveing 3mb down and 384k up from cable 🙂 but i can settle on 1500k/384k because i have PPPoE support.
Ok it looks like im gonna go with Verizon 1500/384 dsl. Thanks all.
Edit: Remind me to move to sweden 🙁 i want my 10m up and down.
