Need help finding a Dell fan
bctbct
I am having a hard time finding a online vendor for a replacement fan for a Dell 4600. Here is whats in it. Any ideas? thanks
DELL, J0531, 12VDC Fan ( Datech 9238-12HBTL-A 3w) DELL POWEREDGE 3-prong
No it look similar to this
Text
apprentley the fan is proprietary and must be oem or dell. I just cant find one anywhere other than dell which is closed until tomm. according to their site.
You can find direct replacements but the price will choke you. Here ya go:
http://www.serverpartswarehouse.com/j0531.html I don't know anyone who would pay that much for a used pull... Too bad you don't have the complete specs for the fan as you could probably replace with a normal 92x38mm fan (cut and splice the wires as the connector is non-standard and fit it into the Dell housing) it's just that JMC Datech are hard to find in the states and the numbers on yours are to their old numbering scheme. Here's another possibility:
http://www.xlineonline.com/9238.html
.bh.
Oh, I think that Dell's business CSRs and parts ordering lines are available by phone or email 24/7 .
.bh.
