Just wonderind if anyone out there knows a site where I can get a 6+2 pin Pci-E connector so I can make a custom 6 to 6+2 pin cable for my Antec NEO HE 500w PSU.
Not a good idea. The 8 pin connection is meant to offer a full 12A if the card in question requires it. Thats double what your PSU is rated to support on that connector. If you need the 6=2 for some reason then get a new PSU.
