Need help finding 5 1/4" USB 2.0, Firewire, Smartmedia, etc. Drive Bay Hub
Toolman
989
I have been trying to find a 5 1/4" drive bay hub that has at least 2 USB 2.0 ports, 2 Firewire ports, Smartmedia port and also can accept most other flash media. I have found one that has most of these ports except it doesn't have the USB 2.0 and it fits a 3 1/2" drive bay, which I don't want. LINK
Any help would be appreciated.
XMan
49
You mean 5.25? Like CD-ROM sized? The only ones I've seen are 3.5"
Toolman
989
Yeah 5 1/4" CD size, I mispoke, but if you measure across the front of it, it is 5 3/4" technically.
I found something similar by SIIG, but it has no media reading capabilities, just 4 USB 2.0 ports and 2 Firewire ports
Link
Jamie571
267
Try Frontx.com. They have configurable 5 1/4" Hubs. Although they don't carry a Smart Card Reader, they are working on one soon that can be added to their hub. They are very highy rated by many mod sites.
HERE
Jamie
foofoo
1,344
hi,
the soyo will get you most of the way there, just need firewire which you can mod if you want.
interesting question, i havent seen an all-in-one either.
link
